MasterLiquid ML120RS RGB image number 0
MasterLiquid ML120RS RGB image number 1
MasterLiquid ML120RS RGB image number 2
MasterLiquid ML120RS RGB image number 3
MasterLiquid ML120RS RGB image number 4
MasterLiquid ML120RS RGB image number 5
쿨해지는 가장 컬러풀한 방법
사양
  • Radiator Material Aluminum
  • Pump Dimensions 83.6 x 71.8 x 52.7 mm / 3.3 x 2.8 x 2.1 inch
  • Pump MTTF 70,000 Hours
  • Legacy Cooling
  • Fan Quantity 2 PCS
  • Pump Connector 3-Pin
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Pump Noise Level < 15 dBA
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Radiator Size 120
  • Fan Air Pressure 2.34 mmH2O (Max)
  • CPU Socket LGA1366
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Dimensions (L x W x H) 157 x 119.6 x 27mm / 6.2 x 4.7 x 1.1 inch
  • Fan Airflow 66.7 CFM (Max)
  • EAN code 4719512071625
  • UPC code 884102044120
  • Product Number MLX-S12M-A20PC-R1
