MasterFan MF140R ARGB image number 0
MasterFan MF140R ARGB image number 1
MasterFan MF140R ARGB image number 2
MasterFan MF140R ARGB image number 3
MasterFan MF140R ARGB image number 4
MasterFan MF140R ARGB image number 5
MasterFan MF140R ARGB image number 6
LIVE YOUR LIFE IN THE MOST COLORFUL WAY
사양
  • RGB Rated Voltage 5 VDC
  • Fan - LED Lighting ARGB
  • Cooler Type Case Fan
  • Fan Bearing Type LDB
  • Fan L-10 Life 40,000 Hours
  • Fan Size 140
  • RGB Rated Current 0.34A
  • Fan MTTF 280,000 Hours
  • Fan Safety Current 0.6A
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Speed 650-1500 RPM ± 10%
  • Series MasterFan
  • Fan Weight 142g
  • Fan Air Pressure 1.6 mmH2O
  • Product Number R4-140R-15PC-R1
  • Fan Noise Level 33.5 dBA
  • Fan Airflow 90 CFM ± 10%
