MasterFan MF120 Halo 3in1 화이트 에디션 image number 0
MasterFan MF120 Halo 3in1 화이트 에디션 image number 1
MasterFan MF120 Halo 3in1 화이트 에디션 image number 2
MasterFan MF120 Halo 3in1 화이트 에디션 image number 3
MasterFan MF120 Halo 3in1 화이트 에디션 image number 4
빛의 헤일로
Cooler Master가 MasterFan Halo 시리즈에 새로운 제품인 MF120 Halo 3in1 화이트 에디션을 선보입니다.
사양
  • RGB Rated Voltage 5 VDC
  • RGB Connector 3-Pin
  • Fan - LED Lighting ARGB
  • Number of LEDs 24pcs x 3
  • Fan Air Pressure 1.6 mmH2O ± 10%
  • Cooler Type Case Fan
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Fan Noise Level 6 - 30 dBA
  • Fan Safety Current 0.37A
  • Fan Connector 4-Pin PWM
  • Fan Size 120
  • RGB Rated Current 0.55A (0.8A Max)
  • Note Products manufactured after 1st June 2021 are Addressable Gen 2 RGB LEDs
  • Fan Profiles Addressable Gen 2 RGB
  • Series MasterFan
  • Fan Power Consumption 3.0W
  • Fan Rated Current 0.25A
  • Fan Weight 180g x 3
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 47.2 CFM ± 10%
  • Product Number MFL-B2DW-183PA-R1
