MasterBox MB400L image number 0
MasterBox MB400L image number 1
MasterBox MB400L image number 2
MasterBox MB400L image number 3
MasterBox MB400L image number 4
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
실용적인 디자인
MasterBox MB400L
Brushed Front Panel
Brushed Front Panel
A brushed finish spans the entire front panel for an elegant and minimalistic design.
Hexagon Gleam
Hexagon Gleam
If an optional, illuminated fan is installed, the Cooler Master hexagon logo will capture light from the fan and emit a glow on the front panel.
Mesh Intakes
Mesh Intakes
Large, mesh intakes span each side of the front panel to provide additional airflow to system.
With/Without Odd Support
Depending on preference, an ODD version of the chassis is available. If an ODD is not preferred, a cleaner appearance and more cooling options on the top and front panels are supported.
Adaptable Drive Cage
The drive cage is (re)movable, able to shift toward the front to accommodate for PSU space, backwards to provide additional radiator space, or even completely removed.
Versatile Cooling Options
Support for up to six fans and front, top, and rear radiator support ensure that performance is not compromised.
Room For Upgrades
Room For Upgrades
Support for up to a 344mm graphics card, a 166mm CPU cooler, and up to a 325mm PSU in length provides room for upgrades to stay ahead of the game.
사양
  • 모델 번호 MCB-B400L-KGNN-S00
  • 색상 Black
  • 소재 - 외부 Steel, Plastic
  • 소재 - 좌측 사이드 패널 Tempered Glass, Steel
  • 크기 (길이 x 너비 x 높이) 411 x 218 x 410mm (TG / Incl. Protrusions), 411 x 210 x 410mm (Steel / Incl. Protrusions), 396 x 210 x 400mm (Excl. Protrusions)
  • 용량 33.26L (Excl. Protrusions)
  • 지원 메인보드 Mini-ITX, Micro-ATX
  • 확장 슬롯 4
  • 5.25" 드라이브 베이 0
  • 3.5" 드라이브 베이 2
  • 2.5인치 드라이브 베이 2
  • I/O 패널 - USB 포트 Option 1: 2x USB 3.2 Gen 1 (USB 3.0) / Option2: 1x USB 3.2 Gen 1 (USB 3.0), 1x USB 2.0 / *options may vary per region
  • I/O 패널 - 오디오 입력 / 출력 1x 3.5mm Headset Jack (Audio+Mic)
  • 사전 설치 팬 - 상단 N/A
  • 사전 설치 팬 - 전면 N/A
  • 사전 설치된 팬 - 후면 1x 120mm Black Fan* / *options may vary per region
  • 팬 지원 - 상단 2x 120/140mm
  • 팬 지원 - 전면 3x 120mm, 2x 140mm (Mount behind the front plate)
  • 팬 지원 - 후면 1x 120mm
  • 라디에이터 지원 - 상단 120 / 240mm
  • 라디에이터 지원 - 전면 120 / 140 / 240 / 280mm
  • 라디에이터 지원 - 후면 120mm
  • 여유 공간 - CPU 쿨러 Steel: 167mm, TG: 166mm
  • 여유 공간 - 파워서플라이 325mm (w/o front radiator & HDD cage)
  • 클리어런스 - 그래픽 카드 344mm
  • 케이블 라우팅 18-22mm
  • 전원 공급 장치 지원 Bottom Mount, ATX
  • 먼지 필터 Front, Top, Bottom
  • 보증 2 years
  • 크기 Mini Tower
  • 시리즈 MasterBox Series
