MasterBox MB400L image number 0
MasterBox MB400L image number 1
MasterBox MB400L image number 2
MasterBox MB400L image number 3
MasterBox MB400L image number 4
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
Sensible by design
MasterBox MB400L
Each element of the MasterBox MB400L was created from an elegant palette. With a brushed finish, subtle hue, and the minimalistic Cooler Master...
Brushed Front Panel
Brushed Front Panel
A brushed finish spans the entire front panel for an elegant and minimalistic design.
Hexagon Gleam
Hexagon Gleam
If an optional, illuminated fan is installed, the Cooler Master hexagon logo will capture light from the fan and emit a glow on the front panel.
Mesh Intakes
Mesh Intakes
Large, mesh intakes span each side of the front panel to provide additional airflow to system.
With/Without Odd Support
Depending on preference, an ODD version of the chassis is available. If an ODD is not preferred, a cleaner appearance and more cooling options on the top and front panels are supported.
Adaptable Drive Cage
The drive cage is (re)movable, able to shift toward the front to accommodate for PSU space, backwards to provide additional radiator space, or even completely removed.
Versatile Cooling Options
Support for up to six fans and front, top, and rear radiator support ensure that performance is not compromised.
Room For Upgrades
Room For Upgrades
Support for up to a 344mm graphics card, a 166mm CPU cooler, and up to a 325mm PSU in length provides room for upgrades to stay ahead of the game.
사양
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Clearance - PSU 140mm (HDD cage in backmost position)
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mini Tower
  • 2.5" Drive Bays 2
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Materials Mesh
  • Fan Support - Top 2x 140mm
  • Cable Routing 18-22mm
  • Clearance - PSU 325mm (w/o front radiator & HDD cage)
  • Expansion Slots 4
  • Fan Support - Top 2x 120mm
  • Clearance - CPU Cooler Steel: 167mm
  • Weight 5.47kg
  • Fan Support - Front Mount behind the front plate
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - GFX 344mm
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0)
  • Dimensions (L x W x H) 411 x 210 x 410mm (Steel Incl. Protrusions)
  • Dimensions (L x W x H) 396 x 210 x 400mm (Excl. Protrusions)
  • Model Number MCB-B400L-KNNN-S00
