Hyper D92 image number 0
Hyper D92 image number 1
Hyper D92 image number 2
Hyper D92 image number 3
Hyper D92
Hyper D92
Hyper D92
Hyper D92
Hyper D92
Hyper D92
사양
  • Heat Pipe Dimensions Ø6mm
  • Note *AMD AM4 upgrade kit needed, please visit: http://bit.ly/31244ne
  • Cooler Type Air Cooler
  • Fan MTTF 40,000 Hours
  • Legacy Cooling
  • Weight 636g / 1.4lb
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan Bearing Type LDB
  • Series Hyper
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • Fan Airflow 15.7 - 54.8 CFM ± 10%
  • CPU Socket LGA1366
  • CPU Socket LGA1156
  • Fan Speed 800-2800 RPM (PWM) ± 10%
  • CPU Socket LGA1155
  • Fan Air Pressure 0.35 - 4.27 mmH2O ± 10%
  • Heat Sink Dimensions (L x W x H) 145 x 124.7 x 85 mm / 5.7 x 4.9 x 3.3 inch
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Weight 448g / 0.99lb
  • CPU Socket LGA775
  • Dimensions (L x W x H) 146.4 x 128.9 x 96.6 mm / 5.8 x 5.1 x 3.8 inch
  • Fan Noise Level 10 - 33 dBA
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • Product Number RR-HD92-28PK-R1
  • EAN code 4719512047514
  • UPC code 884102026508
  • CPU Socket AM2
  • CPU Socket FM2+
  • Heat Sink Material 4 Continuous Direct Contact Heat Pipes
  • Fan Power Consumption 2.88W (Max)
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Rated Current 0.24A + 10% (Max)
