Hyper 212 LED Turbo ARGB image number 0
Hyper 212 LED Turbo ARGB image number 1
Hyper 212 LED Turbo ARGB image number 2
Hyper 212 LED Turbo ARGB image number 3
Hyper 212 LED Turbo ARGB image number 4
Hyper 212 LED Turbo ARGB image number 5
Hyper 212 LED Turbo ARGB image number 6
Hyper 212 LED Turbo ARGB image number 7
Hyper 212 LED Turbo ARGB image number 8
THE LEGEND CONTINUES
The Hyper 212 LED Turbo ARGB showcases our upgraded SickleFlow 120 ARGB fans with a dual fan setup for Push-Pull configuration.
사양
  • Cooler Type Air Cooler
  • Fan Quantity 2 PCS
  • Heatpipes 4
  • Fan Bearing Type LDB
  • Fan Safety Current 0.37A
  • Series Hyper
  • CPU Socket LGA1700
  • CPU Socket LGA1200
  • Fan MTTF >160,000 Hours
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Heat Sink Material 4 Heat Pipes
  • CPU Socket LGA1151
  • Color Black & Silver
  • CPU Socket LGA1150
  • Fan Power Consumption 1.8W
  • Fan Rated Current 0.15A
  • CPU Socket AM5
  • CPU Socket AM4
  • Heat Sink Material Direct Contact
  • Note AM5 and LGA 1700 mounting kits are included from New Package Design. You may obtain the required mounting kits for products with older package design through the CM store, regional resellers or distributors. Older CPU sockets (LGA 2066, LGA2011-v3, LGA2011, LGA1366, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1) will not be supported anymore from New Package Design.
  • Fan Air Pressure 2.5 mmH2O (Max)
  • Fan Noise Level 27 dBA (Max)
  • Fan Speed 650-1800 RPM (PWM) ± 5%
  • Dimensions (L x W x H) 120 x 110 x 159 mm / 4.7 x 4.3 x 6.3 inch
  • Fan Airflow 62 CFM (Max)
  • Product Number RR-212TK-18PA-R1
