GX III Gold 1250 ATX 3.1 image number 0
GX III Gold 1250 ATX 3.1 image number 1
GX III Gold 1250 ATX 3.1 image number 2
GX III Gold 1250 ATX 3.1 image number 3
GX III Gold 1250 ATX 3.1 image number 4
GX III Gold 1250 ATX 3.1 image number 5
GX III Gold 1250 ATX 3.1 image number 6
GX III Gold 1250 ATX 3.1 image number 7
우아함 속의 강렬함
• 혁신적이고 세련된 디자인
• ATX 3.1 지원 및 90도 12V-2x6 케이블
• 최적화된 조용한 냉각 성능
• 저부하 시 Titanium 효율
• 완전 모듈식 케이블
• 10년 보증
Innovative, Streamlined Design
ATX 3.1 Support & a Durable 90-degree 12V-2x6 Cable
Includes ATX 3.1 support and a 90-degree 12V-2X6 PCle 5.1 connector featuring higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
Exceptional Efficiency
This 80 Plus Gold certified unit can achieve Titanium level efficiency at light loads in a 115V test.
Optimized Thermal Performance
An anodic-coated heat sink keeps average temperatures 5℃ lower than a traditional heat sink for enhanced durability and a prolonged life span.
Fully Modular Cabling
Zero-RPM Mode
This unit includes a smart thermal control mode that defaults to zero spin.
PSU Calculator
사양
  • Model MPX-C503-AFAG-BKR
  • Input Current 15-7A
  • Dimensions 160 x 150 x 86 mm
  • Fan Size 135mm
  • Fan Bearing FDB
  • Fan Speed 2300 RPM
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 16ms
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 3
  • 12V-2x6 Connectors 1
  • Series GX Series
  • 80 Plus Gold
  • Category Above 750W
  • Watts 1250W
