GeminII SF524 image number 0
GeminII SF524 image number 1
GeminII SF524 image number 2
GeminII SF524 image number 3
GeminII SF524 image number 4
GeminII SF524 image number 5
GeminII SF524 image number 6
GeminII SF524 image number 7
GeminII SF524 image number 8
GeminII SF524 image number 9
GeminII SF524 image number 10
GeminII SF524 image number 11
GeminII SF524 image number 12
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
GeminII SF524
사양
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Fan Life Expectancy 40,000 Hours
  • CPU Support Core™ i7 Extreme
  • Connector 3-Pin
  • Legacy Cooling
  • Fan Bearing Type Long Life Sleeve Bearing
  • CPU Support Core™ i5
  • Note *The supplied accessories may differ by country or area. Please check with your local distributor for further details.
  • CPU Support Core™ i3
  • CPU Support Core™2 Extreme
  • CPU Support Core™2 Quad
  • Series GeminII
  • Fan Rated Current 0.1A
  • CPU Socket LGA1366
  • CPU Support Core™2 Duo
  • CPU Support Pentium
  • Fan Power Consumption 1.2W
  • Heat Sink Material 5 Heat Pipes
  • CPU Socket LGA1156
  • CPU Support Celeron
  • CPU Support AMD FX-Series
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Support AMD A-Series
  • Fan Speed 1300 RPM ± 10% (900 RPM with silent mode adapter)
  • CPU Support AMD Phenom™ II X4
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Support AMD Phenom™ II X3
  • Fan Air Pressure 1.14 mmH2O ± 10% (0.55 mmH2O @ 900RPM)
  • Fan Weight 102g / 0.23lb
  • CPU Support AMD Phenom™ II X2
  • CPU Support AMD Phenom™ X4
  • CPU Support AMD Phenom™ X3
  • CPU Support AMD Athlon™ II X4
  • CPU Socket AM3+
  • Heat Sink Dimensions (L x W x H) 144 x 144 x 78 mm / 5.7 x 5.7 x 3.1 inch
  • CPU Socket AM3
  • CPU Support AMD Athlon™ II X3
  • CPU Support AMD Athlon™ II X2
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Support AMD Athlon™ X2
  • Heat Sink Weight 490g / 1.08lb
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Support AMD Sempron™
  • Dimensions (L x W x H) 144 x 144 x 105 mm / 5.7 x 5.7 x 4.1 inch
  • Heat Sink Material Copper Base
  • CPU Socket FM1
  • Fan Airflow 36.4 - 52.6 CFM ± 10%
  • Product Number RR-G524-13FK-R1
  • Fan Noise Level 22.5 dBA (16.1 dBA @ 900RPM)
