ERGOSTAND IV image number 0
ERGOSTAND IV image number 1
ERGOSTAND IV
ERGOSTAND IV
간단하면서도 강력 함
ERGOSTAND IV
ERGOSTAND IV
Ergostand IV
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
Ergostand IV
Ergostand IV
Ergonomic Design
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
Full Mesh Board
Led Strip & Additional USB Hub
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
Silent Cooling
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
사양
  • Product Number R9-NBS-E42K-GP
  • Color Black
  • Material Metal Mesh, Plastic, Rubber
  • Strip LED Blue
  • Dimensions (L x W x H) 370 x 265 x 40 mm
  • Fan Dimensions (L x W x H) 140 x 140 x 15 mm / 5.5 x 5.5 x 0.6 inch
  • Fan Speed 700–1400 RPM ± 150
  • Fan Airflow 46.8 CFM ± 10%
  • Fan Air Pressure 1.24 mmH2O
  • Fan Noise Level 29 dBA (Max)
  • Power USB 5V DC
  • USB USB 2.0 x 4, Mini x 1, Micro x 1
  • Current Consumption 0.20A
  • Power Consumption 1.0W
  • Compatibility Supports up to 17" laptops
  • Cooler Type Notebook Cooler
  • Series Ergostand
