Elite 690 Wood image number 0
Elite 690 Wood image number 1
Elite 690 Wood image number 2
Elite 690 Wood image number 3
Elite 690 Wood image number 4
Elite 690 Wood image number 5
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Natural Aesthetics. Immersive View. Advanced Cooling.
Elite 690 Wood
The Elite 690 features dual tempered glass panels to showcase your build, while a wood-textured front accent and mesh intake blend warmth with airflow efficiency. With top and bottom ventilation for vertical cooling, it supports versatile fan and radiator setups—perfect for performance-driven or style-focused builds.
270° Panoramic Tempered Glass
Beveled glass panels create an immersive, seamless showcase of your build.
Optimized Tower with PSU Chamber
Vertical layout separates thermal zones for better airflow and cleaner cable routing.
Vertical Cooling Architecture
Up to 10 fans in a bottom-to-top layout maximize airflow and cooling.
Natural Wood Front Panel
Crafted from real wood, the front panel adds a warm, organic touch to any space.
High-Performance Radiator Support
Top 360mm and side 240mm radiator support for powerful cooling setups.
Pre-installed ARGB Fans with Sync
Includes 3 daisy-chainable ARGB fans with full motherboard lighting sync support.
Top & Bottom Mesh Ventilation
Mesh panels ensure enhanced airflow and system-wide thermal performance.
Next-Gen GPU Ready
Supports up to 425mm GPUs—ready for RTX 50 Series and beyond.
High-Speed I/O Panel
USB 3.2 Gen 2x2 Type-C and dual USB 3.0 ports for blazing-fast connectivity.
사양
  • 모델 번호 Black: E690-KHNN-S00, White: E690-WHNN-S00
  • 색상 Black / White
  • 소재 - 전면 패널 Tempered Glass + Wood
  • 소재 - 측면 패널(왼쪽) Tempered Glass
  • 소재 - 사이드 패널(오른쪽) Steel
  • 크기 (길이 x 너비 x 높이) 434 x 218 x 454 mm (Incl. Protrusions), 430 x 218 x 435 mm (Excl. Protrusions)
  • 용량 42.93 L (Liters Incl. Protrusions)
  • 지원 메인보드 ITX / Micro-ATX / ATX
  • 확장 슬롯 7
  • 5.25" 드라이브 베이 0
  • 3.5" 드라이브 베이 1 (Max. 2)
  • 2.5인치 드라이브 베이 1 (Max. 2)
  • I/O 패널 - USB 포트 1 x USB Type C 20Gbps, 2 x USB 3.0
  • I/O 패널 - 오디오 입력 / 출력 1x 3.5mm Combo
  • 사전 설치된 팬 - 후면 1x 120mm ARGB PWM
  • 사전 설치 팬 - 측면 장착 2x 120mm ARGB PWM reverse fan
  • 팬 지원 - 상단 2x 140mm / 3x 120mm
  • 팬 지원 - 후면 1x 120mm
  • 팬 지원 - 측면 장착 2x 120mm
  • 팬 지원 - 하단 3x 120mm
  • 라디에이터 지원 - 상단 120 / 240 / 360 (Max height 45mm)
  • 라디에이터 지원 - 하단 120 / 240 / 360mm
  • 라디에이터 지원 - 측면 장착 120 / 240mm
  • 여유 공간 - CPU 쿨러 170mm
  • 여유 공간 - 파워서플라이 250mm
  • 클리어런스 - 그래픽 카드 425mm
  • 전원 공급 장치 지원 ATX
  • 보증 2 years
  • 크기 Mid Tower
  • 시리즈 Elite Series
