Elite 481 Wood image number 0
Elite 481 Wood image number 1
Elite 481 Wood image number 2
Elite 481 Wood image number 3
Elite 481 Wood image number 4
Elite 481 Wood image number 5
Elite 481 Wood
Elite 481 Wood
Elite 481 Wood
Elite 481 Wood
Elite 481 Wood
Elite 481 Wood
Where Technology Meets Nature
Elite 481 Wood
The Elite 481 Wood brings a warm, home-friendly aesthetic to high-performance PC builds. Featuring a compact dual-chamber mATX layout and a front panel crafted from real natural wood, it blends modern performance with organic design elements. With seamless tempered glass panels, vertical cooling support, and full-size radiator compatibility, the Elite 481 Wood is a versatile chassis that fits effortlessly into living spaces, creative studios, or stylish gaming setups.
Natural Wood Front Panel
A genuine wood front panel brings warm, organic aesthetics—perfect for homes, studios, or gaming setups.
270° Seamless Panoramic View
Dual tempered glass panels with 45° bevels offer a clean, wide-angle showcase of your build and lighting.
Pre-installed ARGB Fans with Sync Support
Includes 3 ARGB fans (2 reverse-blade intake + 1 exhaust), daisy-chainable and fully compatible with major motherboard lighting software.
Vertical Cooling with Extreme Compatibility
Up to 9 fan mounts and support for dual 360mm radiators (top & bottom) plus a 280mm side radiator—delivering high-end thermal performance in a compact frame.
RTX 50 Series Ready
Supports GPUs up to 410mm in length for full compatibility with next-gen flagship graphics cards.
Upgraded
High-Speed
I/O Panel Equipped with USB 3.2 Gen 2x2 Type-C (20Gbps) and dual USB 3.0 ports for fast, modern connectivity.
사양
  • Model Number Black: E481-KHNN-S00, White: E481-WHNN-S00
  • Color(s) Black / White
  • Materials - Front Panel Tempered Glass + Wood
  • Material - Side Panel (Left) Tempered Glass
  • Material - Side Panel (Right) Steel
  • Dimensions (L x W x H) 420 x 285 x 370 mm (Incl. Protrusions), 420 x 285 x 350mm (Excl. Protrusions)
  • Volume 44.29 L (Liters Incl. Protrusions)
  • Motherboard Support ITX / Micro ATX
  • Expansion Slots 5
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1 (Max. 2)
  • 2.5" Drive Bays 2 (Max. 3)
  • I/O Panel - USB Ports 1 x USB Type C 20Gbps, 2 x USB 3.0
  • Pre-installed Fans - Rear 1x 120mm ARGB PWM
  • Pre-installed Fans - Side Mount 2x 120mm ARGB PWM reverse fan
  • Fan Support - Top 3x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Side Mount 2x 140mm / 2x 120mm
  • Fan Support - Bottom 3x 120mm
  • Radiator Support - Top 120 / 240 / 280 / 360mm
  • Radiator Support - Bottom 120 / 240 / 360mm
  • Radiator Support - Side Mount 120 / 240 / 280mm
  • Clearance - CPU Cooler 160mm
  • Clearance - PSU 240mm
  • Clearance - Graphics Card 410mm
  • Power Supply Support ATX
  • Size Mini Tower
  • Series Elite Series
