Elite 302 Lite image number 0
Elite 302 Lite image number 1
Elite 302 Lite image number 2
Elite 302 Lite image number 3
Elite 302 Lite image number 4
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Effortless Efficiency
Elite 302 Lite
High in value and attention to detail, Cooler Master’s Elite 302 lite offers users a cost effective, space conscious solution to gaming and computing needs.
Elite 302 features a large intake grill to ensure a smooth, and efficient running system. The fully black coating and included PSU cover allows for clean builds that are visually appealing as well as functional.
Tool-Less Magnetic Front Panel
Quick and easy maintenance with a tool-free magnetic mesh front panel — engineered for airflow and effortless access.
Ready For High-Performance Cooling
Accommodates up to 6 fans and supports 280mm or 360mm radiators to keep your system performing at its peak.
Breathable PSU Shroud
Ventilated power supply cover supports both active and passive cooling —
offering flexibility and thermal efficiency.
Front I/O USB Type-C Support
Modern connectivity with a built-in USB Type-C port for faster, streamlined data transmission.
사양
  • 모델 번호 Black: E302L-KGNN-S00​, White: E302L-WGNN-S00​
  • 외부 색상 Black, White
  • 소재 - 외부 Steel
  • 소재 - 사이드 패널 (우측 / 좌측) TG / Steel
  • 크기 (길이 x 너비 x 높이) 390 x 203.5 x 430mm​ (Incl. Protrusions), 377 x 203.5 x 410mm​ (Excl. Protrusions)
  • 부피 (돌출부 포함) 34.13L​
  • 지원 메인보드 Mini-ITX, Micro-ATX
  • 확장 슬롯 4
  • 5.25" 드라이브 베이 N/A
  • 3.5" 드라이브 베이 1
  • 2.5인치 드라이브 베이 1 (Max. 2)
  • I/O 패널 - USB 포트 1x USB 3.2 Gen1 Type A, 1x USB 3.2 Gen1 Type C​
  • I/O 패널 - 오디오 입력 / 출력 1x 3.5mm Combo
  • 팬 지원 - 전면 3x 120mm
  • 팬 지원 - 상단 2x 120mm / 2x 140mm
  • 팬 지원 - 후면 1x 120mm
  • 사전 설치 팬 - 전면 N/A
  • 사전 설치 팬 - 상단 N/A
  • 사전 설치된 팬 - 후면 1x 120mm Black Fan
  • 라디에이터 지원 - 전면 120 / 240 / *360 mm (*Supported within 60mm thickness)​
  • 라디에이터 지원 - 상단 120 / 140 / 240 / 280mm
  • 라디에이터 지원 - 후면 120mm
  • 여유 공간 - CPU 쿨러 163.5mm
  • 여유 공간 - 파워서플라이 160mm
  • 클리어런스 - 그래픽 카드 365mm (without front fans & radiator)
  • 케이블 라우팅 18.5mm
  • 먼지 필터 Top / Bottom / Front
  • 전원 공급 장치 지원 ATX
  • 보증 2 years
  • 크기 Mini Tower
  • 시리즈 Elite Series
