Large Support, Minimized Footprint
Despite its compact size, Elite 301 supports up to 365mm graphics cards, 163.5mm CPU Coolers, providing solid potential for future upgrades.
손쉬운 효율성
가치와 디테일에 대한 세심함이 뛰어난 Cooler Master의 Elite 301은 게이밍 및 컴퓨팅 요구를 충족하는 비용 효율적이고 공간 활용도가 높은 솔루션을 제공합니다.
Elite 301은 대형 흡기 그릴과 3개의 120mm ARGB 팬을 탑재하여 원활하고 효율적인 시스템 작동을 보장합니다. 완전한 블랙 코팅과 기본 제공되는 PSU 커버는 시각적으로 매력적이면서도 기능적인 깔끔한 빌드를 완성할 수 있게 해줍니다.
Constructed with a substantially large, unrestricted intake grill to ensure that the system runs cool and efficiently. The front panel could be easily removed by magnets, making it easier for daily maintenance.
Supports up to six fans and 280mm radiator to ensure that performance is not compromised.
Pre-installed with 3x 120mm ARGB fans, providing considerable airflow and adds a layer of style to the system.
The PSU cover is ventilated on top of the power supply location, allowing actively cooled units to be installed in multiple orientations, while maintaining support for passively cooled power supplies.
