글로벌 본사
대만 타이베이시 네이후구 신후 1로 398호
간단하면서도 강력 함
ERGOSTAND IV
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
