Cooler Master G Gold 750 V2 | An every day ATX 3.1 upgrade image number 0
Cooler Master G Gold 750 V2 | An every day ATX 3.1 upgrade image number 1
Power Evolved
G Gold V2, the upgraded version of the G Gold featuring ATX 3.1 support, high temperature resilience and 80 Plus Gold efficiency.
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, the 750W unit is optimized for ideal compatibility with 40 series GPUs.
Embossed Cable
Quiet HDB Fan​
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
High Temperature Resilience
사양
  • Model MPE-7502-ACAAG
  • Input Current 10-6A
  • Dimensions 140 x 150 x 86 mm / 5.5 x 5.9 x 3.4 inch
  • Fan Bearing HDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time >16ms
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • Warranty 5 Years
  • Series G Series
  • 80 Plus Gold
  • Modular Non Modular
  • Category 500 to 750W
  • Watts 750W
