Storm Controller Cradle image number 0
Storm Controller Cradle image number 1
Storm Controller Cradle image number 2
Storm Controller Cradle image number 3
Storm Controller Cradle image number 4
Storm Controller Cradle image number 5
Mobile Phone Cradle Attachment
The phone cradle attachment has an intuitive, easy-adjust system, allowing you to set-and-play the phone in any position you like with minimal hassle.
With the optional phone cradle attachment, gaming anywhere is even more convenient and accessible. The cradle can be utilized in multiple angles and can be set on a desk or other objects for even more convenience. The phone cradle attachment also has an intuitive, easy-adjust system, allowing you to set-and-play the phone in any position you like with minimal hassle.
Double-hinge Adjustment
With dual-hinges, the Storm Cradle is able to adjust to any angle you need, giving you perfect control over how you want to game while still remaining sturdy and reliable.
Hands Free
Hands Free
The cradle can be used as a normal mobile phone holder by laying it directly onto the table. Kick back, relax and play some games wherever you are.
Easy Installation
Easy Installation
Easy Installation
사양
  • Product Number CMI-GSCXC-BK1
  • Function Mobile Phone Cradle
  • Double Hinge Adjustment Up to 220 degree of adjustment
  • Expandable Range Expanding Range: 6.5-8.5 cm
  • Material Plastic
  • Warranty DOA replacement only
  • Product 액세서리
