Hybrid M Massage Gaming Chair image number 0
Hybrid M Massage Gaming Chair image number 1
Hybrid M Massage Gaming Chair image number 2
Hybrid M Massage Gaming Chair image number 3
Hybrid M Massage Gaming Chair image number 4
Hybrid M Massage Gaming Chair image number 5
Hybrid M Massage Gaming Chair image number 6
Hybrid M Massage Gaming Chair image number 7
Hybrid M Massage Gaming Chair image number 8
Hybrid M Massage Gaming Chair image number 9
Hybrid M Massage Gaming Chair image number 10
Hybrid M Massage Gaming Chair image number 11
Hybrid M Massage Gaming Chair image number 12
Hybrid M is the continuation of our Hybrid 1’s innovative design that bridges the void between work and play.
Relaxation at Your Command
Say goodbye to the perils of prolonged sitting! The Hybrid M Chair is the game-changer you've been waiting for, designed to tackle the muscle pain and discomfort that plague gamers and office warriors alike.
Massage Control App
CUSTOMIZE YOUR MASSAGE YOUR WAY
With the Hybrid M App, you're in control. Record and personalize your massage programs effortlessly or simply use the built-in joystick in the armrest to adjust your massage. Whether you crave a soothing, stress-relieving session or a powerful, invigorating massage, it's all at your fingertips.
*Android Playstore App in development.
Our Achievements
AWARDS
Built-in Massage
NO CORDS, NO LIMITS, MASSAGE ANYWHERE
Unrivaled freedom with the Hybrid M, discover the experience.
Comfort
ADJUSTABLE NECK SUPPORT
Comfort
UNIBODY COLD MOLDED FOAM
75MM
SILENT CASTER
Adjustability
3D ARMREST
4CLASS
GAS LIFT
Quick Stow Magnetic  Lumbar Support
Comfort
Hybrid M's Magnetic Lumbar Support provides a convenient solution for comfort and support. With fast magnetic height adjustment, users enjoy personalized comfort at their fingertips. During the massage function, the lumbar support can be swiftly stowed away under the seat, keeping it out of sight but always close by. Experience unparalleled convenience, functionality, and ergonomic support with Hybrid M's Magnetic Lumbar Support System.
Premium Steel Frame  And Aluminum Base  Construction
Materials
Made from a rock-steady steel frame in combination with a premium aluminum base, the Hybrid M is built with high-quality materials that is not only reliable, but will last for years on end.
Video Tutorial
EASY SETUP & CUSTOMIZATION
The official step-by-step guide to assembling your new Hybrid M Chair and customizing it to perfection using the Cooler Master app.
Chair Recommendation
TABLE OF MEASURES
사양
  • Product Number CMI-GCHYBM-BK
  • Color Black
  • Total Height Range 137-147 cm / 53.9"-57.8"
  • Backrest Height 78 cm / 30.7"
  • Backrest Width 54 cm / 21.3"
  • Armrest to Armrest 75 cm / 29.5"
  • Seat Width (including sides) 61 cm / 24.0"
  • Sitting Area 61 cm / 24.0"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 68 cm / 26.8"
  • Steel Plate Thickness 1.5 mm
  • Armrest Adjustability 29-36 cm / 11.4"-14.2"
  • Floor to Seat Top 48-58 cm / 18.9"-22.8"
  • Height Adjustability 10 cm / 3.9"
  • Recline 90-120 degree
  • Armrest 3D
  • Headrest Integrated headrest (up/down)
  • Lumbar Support Magnetic lumbar support
  • Outer Material Backrest: MuscleFlex® Mesh
  • Outer Material Seatbase: Perforated PU
  • Inner Material High density cold-molded foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Max. Weight Load 120 kg / 265 lbs
  • Chair Type Hybrid Series
  • Product 의자
