GA2501 Gaming Monitor image number 0
GA2501 Gaming Monitor image number 1
GA2501 Gaming Monitor image number 2
GA2501 Gaming Monitor image number 3
GA2501 Gaming Monitor image number 4
GA2501 Gaming Monitor image number 5
GA2501 Gaming Monitor image number 6
GA2501 Gaming Monitor image number 7
GA2501 Gaming Monitor image number 8
GA2501 Gaming Monitor image number 9
GA2501 Gaming Monitor image number 10
GA2501 Gaming Monitor image number 11
GA2501 Gaming Monitor image number 12
Dive Into The Gaming World
The GA2501 is designed for game players who want to enjoy the entry refresh rate experience.
Experience better gaming sessions
EYE-FRIENDLY LOW BLUE LIGHT AND FLICKER FREE
사양
  • Product Number CMI-GA2501
  • Screen Size 24.5"
  • Ratio 16:9
  • Panel Type Flat Series
  • Panel IPS 16.7M (6 bit + FRC)
  • Resolution FHD 1920x1080
  • Frame Rate 100 Hz
  • Contrast Ratio 1300:1
  • Brightness 250 nits (Typical)
  • HDR N/A
  • HDR Peak Brightness N/A
  • Dimming Zones N/A
  • Color Gamut DCI-P3 84% (Typ., CIE 1976), Adobe RGB 84% (Typ., CIE 1931), sRGB 109% (Typ., CIE 1931)
  • I/O - VGA 1
  • I/O - HDMI 1.4 1
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • Response Time 1ms (MPRT), 4ms (GtG)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • Power Consumption 24W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment N/A
  • Height Adjustment N/A
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Monitor Series GA Series
  • Product 모니터
  • Panel Type IPS
