GA241 Gaming Monitor image number 0
GA241 Gaming Monitor image number 1
GA241 Gaming Monitor image number 2
GA241 Gaming Monitor image number 3
GA241 Gaming Monitor image number 4
GA241 Gaming Monitor image number 5
게임의 세계로 뛰어들다
The GA241 is designed for game players who want to enjoy the entry refresh rate experience.
Feature
100Hz + 1ms
GA241 provides a fluid 100Hz refresh rate with 1ms response time, giving clearer and more responsive images for gaming as well as overall productivity uses.
DEEPER ENHANCED CONTRAST
GA241's VA panel produces deeper, darker blacks for an enhanced contrast level, leading to higher picture quality. With a 4000:1 contrast ratio, GA241's VA panel is capable of reproducing a contrast level 4x higher than that of a standard IPS panel.
 Adaptive Sync
Adaptive Sync
GA241 comes with Adaptive Sync support, providing an extra-smooth, tear-free experience in your games. Gain a competitive edge over your opponents with less motion smearing and clearer visuals in the games you play.
 Low Blue Light and Flicker Free
GA241 is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
Feature
PICTURE MODES
Choose the picture mode your want for any scenario you may encounter.
Feature
Minimalistic Aesthetic
GA241 sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
사양
  • Product Number CMI-GA241
  • Panel Type Flat Series
  • Ratio 16:9
  • Screen Size 23.8"
  • Panel VA 16.7M
  • Resolution FHD 1920x1080
  • Frame Rate 100 Hz
  • Contrast Ratio 4000:1
  • Brightness 250 nits (Typical)
  • Color Gamut sRGB 95%
  • I/O - VGA 1
  • I/O - HDMI 1
  • Response Time 1ms (MPRT)
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Power Consumption 13W
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Monitor Series GA Series
  • Product 모니터
  • Panel Type VA
