The Pixel LED panel also integrates custom patterns and system information via the MasterCTRL software.
⬢ Pixel panel for enhanced personalization
⬢ SickleFlow Edge ARGB fans
⬢ Ultra-low profile pump design
⬢ Quick and easy installation
Engineered with PPS and fiberglass, the MasterLiquid Atmos II pump housing delivers industrial-grade strength, exceptional heat resistance, and unmatched durability—designed for builders who demand long-lasting, high-performance cooling. It also passes extreme testing at 70°C for 3,000 hours and 120 °C for 12 hours*, ensuring reliable performance under the harshest conditions.
*Tested by Cooler Master Lab using only the liquid cooling module. Results may vary by system and conditions.
Los ventiladores SickleFlow Edge de 120mm preinstalados mejoran aún más el rendimiento de enfriamiento y simplifican la instalación del usuario.
The flat design allows installation in cases of different sizes while maintaining strong performance.
A quick-mount kit ensures compatibility with mainstream processor sockets and the pre-installed fans simplify setup.
Due to the varying CPU hotspots across different platforms, there are corresponding mounting bracket solutions tailored for each. We recommend you use the included offset mounting brackets for LGA 1851*, which precisely dissipate 4°C of heat from the center of the CPU.**
*Please check whether your motherboard is compatible with this offset bracket.
**Tested by Cooler Master Lab.
