New
Compact Power, No Compromise.
MasterFrame 400 Mesh
Premium open-frame Micro-ATX case designed for compact performance builds, efficient airflow, and refined structural design inspired by the FreeForm 2.0 platform.
The MasterFrame 400 Mesh is a premium open-frame compact chassis crafted for Micro-ATX and Mini-ITX platforms. Embracing the FreeForm 2.0 design philosophy, it features a precision aluminum frame, dual-orientation support, and enhanced mesh airflow. With premium aesthetics and performance-grade clearance, it empowers creators and builders to push compact PC design further.
Silver
Pre-installed Rear Fan
1x SickleFlow 120 mm ARGB White
Extensive fan support
up to 9 fans, including 200 mm options on front and bottom
Supports Mini-ITX and Micro-ATX motherboards
Radiator support
up to 360 mm at the top
Tempered glass side panel
USB 3.2 Gen 2x2 Type-C
Black
1x SickleFlow 120 mm ARGB Black
Radiator support
FreeForm 2.0 Exo-structure
The exposed aluminum frame supports versatile positioning and adapts seamlessly to both vertical and horizontal layouts.
Dual-Orientation Ready
Stand it tall, lay it flat, or flip it sideways. Detachable feet and a smart, adaptable design make it easy to fit any workspace or creative setup.
*Vertical orientation may require additional accessories or adapters depending on component layout, connector clearance, or cable routing.
Compact Motherboard Compatibility
Supports Mini-ITX and Micro-ATX motherboards, delivering optimal compatibility for compact, high-performance builds without compromising cooling or component clearance.
Ample GPU Clearance
Accommodates graphics cards up to 390mm in length, providing full compatibility for high-end GPUs and future upgrades.
Extensive Cooling Support
Supports up to nine fans, including 200 mm fans compatibility, plus top-mounted 360 mm radiators for superior airflow in a compact build.
*200 mm fan support varies by location and fan thickness.
TOOL-FREE PANEL REMOVAL
Easily remove side panels without tools for quick access and modifications during build or upgrades.
INCLUDED GPU SUPPORT BRACKET
The included GPU support bracket prevents GPU sag and ensures stability during intense gaming or high-performance workloads, maintaining a clean and secure build.
MODERN FRONT I/O
Stay connected and ready for anything—MasterFrame 400 Mesh features USB 3.2 Gen 2x2 Type-C, dual USB 3.2 Gen 1 Type-A, and a combo audio jack for ultra-fast data, charging, and seamless peripheral support.
ARGB VISUAL POWER
Despite its compact size, the MasterFrame 400 Mesh comes alive with a pre-installed 120 mm SickleFlow ARGB fan—quiet, powerful, and fully customizable.
