Dual-Chamber Layout
Keeps hardware and cables separated for a cleaner build.
Pre-order the exclusive full-system MasterFrame 360 Panorama S Limited Edition for style, performance, and next-gen upgrades.
CPU: AMD 9800X3D
Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI
Memory: DDR5 RGB 6000 32GB(16GBx2)
M.2 SSD: Kingston NV3 2TB M.2 2280 NVMe SSD
GPU: Cooler Master CUSTOM RTX5080 MF ARGB 16G GDDR7 OC
PSU: Cooler Master V Platinum 1100 V2
Thermal: Cooler Master MasterLiquid Atmos II 360 LCD
Case: Cooler Master MasterFrame 360 Panorama Craft Edition
Windows OS: Comes Pre-installed with Windows 11 Home
Pre-order Price:
USD $3,099.99 (was $3,599.99 ) – Free Delivery
*Disclaimer: Figures, models, or other display items are for demonstration purposes only and are not included in the product for sale.
The front display stage transforms your PC into a personal showcase - perfect for collectibles, figures, and decorations that reflect your style.
Designed to spotlight your hardware, collectibles, and creativity - MasterFrame 360 Panorama provides a platform to transform your gaming rig into a personal showcase.
Show every detail that defines your build, from powerful hardware to your unique style, all in plain view.
The MasterFrame 360 Panorama showcases Cooler Master’s dedication to personalized expression. The concept was built on the original MasterFrame’s aluminum chassis modular design and further developed in collaboration with acclaimed PC modder “AK Mod” during COMPUTEX 2025. It underwent additional refinement through Cooler Master’s research and development team, ultimately leading to mass production.
The result is the MasterFrame 360 Panorama you see today.
Front display stage to showcase collectibles and add personal style to your limited edition rig.
Supports up to 12×120 mm, 4×140 mm, 4×180 mm, and 4×200 mm fans, or up to 4×360 mm radiators for ultimate thermal performance.
Supports Mini-ITX, Micro-ATX, ATX, and BTF with 110 mm cable clearance for clean, sleek setups.
Pre-installed PCIe 5.0 riser cable enables vertical GPU mounting, ensuring full accessibility of GPU aesthetics.
Pre-order the exclusive MasterFrame 360 Panorama S Limited Edition - a prebuilt system with selected components, available only during this limited pre-order. It comes with the signature features of the iconic MasterFrame 360 Panorama Craft Edition case.
Each unit features an individually numbered, laser-etched stainless steel nameplate for ultimate exclusivity.
Essential ports with a minimal, streamlined design for easy access.
Mounted on the front display stage to illuminate your collectibles with vivid ARGB lighting.
Customized based on the ASUS ROG ASTRAL 5080 OC GPU, featuring Cooler Master’s exclusive thermal solution, unique visual design, and an extendable, customizable fan shroud for personalized fan setups without breaking warranty.
The complete system comes pre-installed with 12 ARGB fans, including 3 on the AIO cooler, to maximize internal airflow and vivid lighting across the entire system.
Features real-time status display on the pump cover and a patented dual-chamber pump design for improved cooling and reliability.
To ensure peace of mind, warranty coverage is provided for each component as follows:
Motherboard / CPU
Due to the component manufacturers’ warranty policy, RMA requests must typically be processed with assistance from your local Cooler Master representative. However, this does not affect your statutory rights. Within the legal warranty period, you may also request support directly from your place of purchase.
DRAM / M.2 SSD
Global warranty is provided by the component manufacturers.
Cooler Master Components (Case / PSU / Thermal / Custom GPU)
Covered under Cooler Master’s local warranty, in accordance with local consumer law.
Important Notice Europe (EEA Customers)
This warranty is provided in addition to, and does not affect, your statutory rights under the applicable consumer protection laws in your country of purchase. In the European Economic Area (EEA), consumers are entitled to a 2-year legal warranty from the date of purchase. Any claims need to be made through the seller.
