New
Effortless Efficiency
Elite 502
The Elite 502 delivers exceptional cooling and performance with its advanced mesh front panel for enhanced airflow. Designed for mid-to-entry-level builders, it supports up to a 420mm radiator, 410mm GPUs, and modern back-connector motherboards, offering a streamlined and efficient building experience at an accessible price.
BACK-CONNECTED MOTHERBOARD SUPPORT​
Supports back-connected motherboard design, freeing up space at the front of the case and providing 33-35mm of space behind the motherboard tray for easier cable management.
OPTIMIZED AIRFLOW​
Equipped with three 120mm ARGB fans, it offers stable cooling performance while adding stunning lighting effects to your build.
USB TYPE-C UPGRADE​
USB Type C port built into the I/O panel allows multi-purpose, streamlined data transmission. ​
ROOM FOR UPDATES​
Supports a 410mm GPU, a 170mm CPU cooler, and ample space for future hardware upgrades.
VERSATILE THERMAL OPTIONS
Supports up to seven 120mm fans and either a top-mounted 360mm radiator or a front-mounted 420mm radiator, offering hyper-effective CPU thermal performance.
REMOVABLE HDD CAGE
The HDD cage is completely removable, providing better access during assembly and system upgrades.
