New
Where Technology Meets Nature
Elite 481 Wood
The Elite 481 Wood brings a warm, home-friendly aesthetic to high-performance PC builds. Featuring a compact dual-chamber mATX layout and a front panel crafted from real natural wood, it blends modern performance with organic design elements. With seamless tempered glass panels, vertical cooling support, and full-size radiator compatibility, the Elite 481 Wood is a versatile chassis that fits effortlessly into living spaces, creative studios, or stylish gaming setups.
Natural Wood Front Panel
A genuine wood front panel brings warm, organic aesthetics—perfect for homes, studios, or gaming setups.
270° Seamless Panoramic View
Dual tempered glass panels with 45° bevels offer a clean, wide-angle showcase of your build and lighting.
Pre-installed ARGB Fans with Sync Support
Includes 3 ARGB fans (2 reverse-blade intake + 1 exhaust), daisy-chainable and fully compatible with major motherboard lighting software.
Vertical Cooling with Extreme Compatibility
Up to 9 fan mounts and support for dual 360mm radiators (top & bottom) plus a 280mm side radiator—delivering high-end thermal performance in a compact frame.
RTX 50 Series Ready
Supports GPUs up to 410mm in length for full compatibility with next-gen flagship graphics cards.
Upgraded
High-Speed
I/O Panel Equipped with USB 3.2 Gen 2x2 Type-C (20Gbps) and dual USB 3.0 ports for fast, modern connectivity.
