Equipped with AMD Ryzen™ 9 7950X 3D CPU, with 16 cores, 32 threads and up to 5.7GHz clock speed, it is the ideal processor for gamers and creators. The processor is cooled with a water block, so heat is removed by liquid cooling and performance is optimized.
![](https://a.storyblok.com/f/281110/520x580/2f949444b9/bento-1.png/m/415x0/smart)
FULL LOAD
1/0 PORTS
Cooling X is equipped with NVIDIA® GeForce™ 4080 graphics card. It's powered by the ultra-efficient NVIDIA Ada Lovelace architecture and 16GB of superfast G6X memory. For increased and stable gaming performance, the GPU is covered by a water block to remove the heat effectively.
![](https://a.storyblok.com/f/281110/520x580/0f45cc3c45/bento-4.png/m/415x0/smart)
