MasterLiquid Core LCD 360 4-inch
Performance builds today do more than push frames. They reflect how you build, what you run, and how you want your system to look. The MasterLiquid Core LCD Series brings cooling and customization together with a 4-inch display that gives your system a clear point of focus.
Under the hood, a redesigned dual-chamber pump improves heat transfer while keeping noise under control. Paired with a three-phase motor, it runs smoothly and consistently, even when your system is under sustained load.
The 4-inch LCD adds a new layer of control without adding complexity. Rotate it to match your build, then customize what you see with system stats, images, or video. Backed by durable materials and reinforced sealing, it’s built to run reliably over time.
