New
Refined for Performance & Style
MasterLiquid Atmos II Stealth Series
⬢ Bundled Flex Kit for Modular Upgrades
⬢ Mobius 120P Fans
⬢ Thicker Radiator for Better Performance
⬢ Ultra-low Profile Pump Design
⬢ Easy Installation
Experience ultimate thermal management with the MasterLiquid Atmos II Stealth. This refined cooling solution features a 29mm thickened radiator for superior heat dissipation and pressure-optimized Mobius 120P fans for silent, high-performance airflow. A sleek, ultra-low-profile pump ensures maximum case compatibility, while the magnetic Flex Kit allows for effortless customization with interchangeable covers. Complete with a universal quick-mount kit and pre-installed fans, the Atmos II Stealth blends sophisticated aesthetics with a streamlined installation process.
VRM FAN
The VRM fan module cools motherboard hot zones with airflow in six directions. It can reduce temperatures by up to 10.2°C*, to improve both stability and performance.
*Tested by Cooler Master Lab.
Precision VRM Cooling
Validated by Cooler Master Lab, the VRM fan delivers targeted cooling, reducing temperatures by up to 10.2°C across critical components for enhanced performance and stability.
Air Pressure
Noise Level
Temperature Drop
Cooling System
DUAL CHAMBER DESIGN
DUAL CHAMBER DESIGN
Patented design
DUAL CHAMBER DESIGN
Improved Quality
Tough. Reliable. Built to Endure.
Engineered with PPS and fiberglass, the MasterLiquid Atmos II pump housing delivers industrial-grade strength, exceptional heat resistance, and unmatched durability—designed for builders who demand long-lasting, high-performance cooling. It also passes extreme testing at 70°C for 3,000 hours and 120 °C for 12 hours*, ensuring reliable performance under the harshest conditions.
*Tested by Cooler Master Lab using only the liquid cooling module. Results may vary by system and conditions.
Interchangeablemagnetictop covers offer versatile customization and effortless swapping.This kit includes base, metallic,and VRM fan options to meet diverse aesthetic and thermal requirements with ease.
Default Cover
Metallic Finish Cover
VRM Fan
ÚLTIMOS VENTILADORES SICKLEFLOW EDGE 120
Los ventiladores SickleFlow Edge de 120mm preinstalados mejoran aún más el rendimiento de enfriamiento y simplifican la instalación del usuario.
An increased radiator thickness—upgraded from 27mm to 29mm—enlarges the heat exchange surface for more efficient heat absorption and dissipation. This enhancement maintains thermal stability during demanding workloads, ensuring reliable cooling when the system reaches peak limits.
The sleek, flat design ensures compatibility with various case sizes while delivering high-performance liquid flow.
Easy Installation
A quick-mount kit provides broad compatibility with mainstream processor sockets, while pre-installed fans simplify the setup process.
Offset Mounting Brackets for LGA 1851
Due to the varying CPU hotspots across different platforms, there are corresponding mounting bracket solutions tailored for each. We recommend you use the included offset mounting brackets for LGA 1851*, which precisely dissipate 4°C of heat from the center of the CPU.**
*Please check whether your motherboard is compatible with this offset bracket.
**Tested by Cooler Master Lab.
INCLUDED CRYOFUZE
THERMAL PASTE
TUBE CLIPS INCLUDED
