New
Clean Design, Ready-to-Go Cooling
Elite 350
The Elite 350 is a compact micro-ATX case designed for clean builds and easy setup. With four pre-installed ARGB fans, wide-ranging component compatibility, and a streamlined interior layout, it provides a balanced foundation for everyday PC builds.
OUT-OF-THE-BOX COOLING & LIGHTING
The Elite 350 comes equipped with four pre-installed 120mm ARGB fans, three in the front and one at the back, delivering great airflow and vibrant lighting straight out of the box.
BUILT FOR MICRO-ATX & MINI-ITX SYSTEMS
The Elite 350 comfortably supports modern components, including full-size GPUs and tower-style CPU coolers. It's an ideal choice for mainstream gaming or creative systems built on micro-ATX or Mini-ITX platforms.
Flexible Airflow Options
Designed with airflow in mind, the Elite 350 supports multiple fan and radiator configurations, allowing users to fine-tune cooling performance based on their workstyle needs. Whether prioritizing a quiet machine or one with enhanced thermal efficiency, the Elite 350 is the perfect choice.
Modern Front I/O
The front I/O panel provides convenient access to the latest connectivity options, including USB Type-C support, ensuring compatibility with most devices and peripherals.
DESIGNED FOR EVERYDAY BUILDS
The Elite 350 is constructed with SPCC steel, tempered glass, and durable plastic components to strike a balance between durability and visual clarity. It's a natural choice for first-time builders and those who want a clean, understated setup.
