Graphics card capacityOne graphics card per holder
RequirementRequires seven PCI case slots
Riser Cable ModelRiser Cable PCIe 3.0
SupportPCI area of your Case
Net Weight0.230Kg
Color(s)Dark Metallic Grey
LegacyAccessories
NoteThis product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
