Controlled Acoustic Performance
Delivers strong cooling performance with a max noise level of 37 dB(A).
Raw Power. Refined Thermals.
Cooler Master Proprietary 3DHP Technology
Intel / AMD Contact-Optimized Base
Dual 120mm LCP PWM Fans
High-Density Thermal Fin Stack
Engine-Inspired Aluminum Covers
3DHP design helps move heat away from the CPU more efficiently, keeping performance steady during rendering, AI tasks, and long production runs.
3DHP technology allows V8 ACE 3DHP to achieve high thermal efficiency in a much more compact size.
Two 120 x 30 mm PWM fans push air through the fin stack for stronger airflow under load.
Dedicated Intel and AMD versions use platform-specific brackets for better fit and improved CPU contact.
LCP fan blades maintain their shape at high speed,
helping keep airflow steady and cooling performance
more consistent under load.
The non-RGB design delivers a refined premium look
that fits creator workstations and enthusiast builds.
