Mobius 120P ARGB image number 0
Mobius 120P ARGB image number 1
Mobius 120P ARGB image number 2
Mobius 120P ARGB
Mobius 120P ARGB
Mobius 120P ARGB
More Balance, More Burst
Mobius 120P ARGB White Edition
Ring Blade Design (RBD)
Pressure Air Acceleration
Absolute Acoustics
Luminescent Light Effects
Addressable Gen 2 RGB
Buy Now
ANTI-VIBRATION DAMPER
ABSOLUTE ACOUSTICS
Sound output fine tuned to the optimal prominence ratio
to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
  • Product Number MFZ-M2DN-24NP2-R1
  • Exterior Color Black
  • Number of LEDs 8pcs
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM
  • Fan Noise Level 30 dBA
  • Fan Air Pressure 3.63 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.18A
  • Fan Safety Current 0.35A
  • Fan Power Consumption 2.16W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.48A
  • Fan Weight 179g / 0.38 lbs
  • Warranty 5 years
