MasterCase H500P Mesh White ARGB image number 0
MasterCase H500P Mesh White ARGB image number 1
MasterCase H500P Mesh White ARGB image number 2
MasterCase H500P Mesh White ARGB image number 3
MasterCase H500P Mesh White ARGB image number 4
MasterCase H500P Mesh White ARGB image number 5
MasterCase H500P Mesh White ARGB image number 6
Mind-Blowing Design
Dual 200mm ARGB Fans
Mesh Front Panel
Build By Design
ARGB Lighting System
Tempered Glass Side Panel
  • Series MasterCase Series
  • Materials Steel
  • Dust Filters Top
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • 5.25" Drive Bays N/A
  • Fan Support - Front 2x 200mm
  • Dust Filters Front
  • Materials Plastic
  • Radiator Support - Rear 140mm
  • Size Mid Tower
  • Color(s) White
  • Materials Tempered Glass
  • Radiator Support - Top 360mm
  • Dust Filters Bottom
  • Fan Support - Top 3x 120/140mm
  • Power Supply Support ATX
  • Radiator Support - Top 280mm
  • Expansion Slots 7+2
  • Motherboard Support E-ATX*
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Clearance - PSU 220mm
  • Materials Mesh
  • Dimensions (L x W x H) 544 x 242 x 542mm / 21.4 x 9.5 x 21.3 inch
  • Fan Support - Top 2x 200mm
  • Expansion Slots (Supports vertical graphics card installation)
  • Motherboard Support (*support for up to 12" x 10.7", will limit cable management features)
  • Clearance - CPU Cooler 190mm
  • Pre-installed Fans - Front 2x 200mm ARGB Fan
  • 2.5" Drive Bays 2 (Max.4)
  • I/O Panel 1x 3.5mm Mic Jack
  • Clearance - GFX 412mm/16.2"
  • Weight 11.3 kg
  • I/O Panel 1x ARGB Controller
  • I/O Panel 1x ARGB 2-to-3 splitter
  • Model Number MCM-H500P-WGNN-S01
  • MasterCase H500P Mesh White ARGB - Product Sheet Download
  • MasterCase H500P Mesh White ARGB - Manual Download
  • Small ARGB Controller - Product Sheet Download
