MasterBox NR200 image number 0
 MasterBox NR200 image number 1
 MasterBox NR200 image number 2
 MasterBox NR200 image number 3
 MasterBox NR200 image number 4
 MasterBox NR200 image number 5
 MasterBox NR200 image number 6
 MasterBox NR200 image number 7
 MasterBox NR200 image number 8
 MasterBox NR200 image number 9
 MasterBox NR200 image number 10
 MasterBox NR200 image number 11
 MasterBox NR200 image number 12
 MasterBox NR200 image number 13
 MasterBox NR200 image number 14
 MasterBox NR200 image number 15
 MasterBox NR200 image number 16
 MasterBox NR200 image number 17
 MasterBox NR200 image number 18
 MasterBox NR200 image number 19
 MasterBox NR200 image number 20
 MasterBox NR200 image number 21
 MasterBox NR200 image number 22
 MasterBox NR200 image number 23
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
 MasterBox NR200
Big Features, Small Size
MasterBox NR200
Unrestricted Cooling Potential
Triple-slot GPU support
Easy, Tool-free access
360 Degree Accessibility
Multiple motherboard support options
Out-of-the-box Custom Cooling Support
High quality materials
Buy Now
  • Materials Steel
  • Radiator Support - Bottom 120mm
  • Dust Filters Top
  • 2.5" / 3.5" Drive Bays (Combo) 1
  • Radiator Support - Side 120mm
  • Radiator Support - Side 140mm
  • 5.25" Drive Bays 0
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Pre-installed Fans - Bottom N/A
  • Fan Support - Side 2x 120/140mm
  • Color(s) White
  • Radiator Support - Bottom 240mm
  • Dust Filters Bottom
  • Radiator Support - Rear 92mm (Not Compatible with Vertical GPU Installation)
  • Radiator Support - Side 240mm
  • Radiator Support - Side 280mm
  • Pre-installed Fans - Top 1x 120mm 650-1800RPM PWM (SickleFlow)
  • Size Mini ITX
  • Dust Filters Left side
  • Volume 18.25L (exlc. Protrusions)
  • Dust Filters Right side
  • Radiator Support - Side (not compatible with vertical GPU installation)
  • Radiator Support - Bottom (recommended for custom loops only)
  • Note Single slot water-cooler GPUs or vertically mounted GPUs are recommended when using bottom radiator position
  • Fan Support - Rear 1x 92mm
  • Fan Support - Bottom 2x 120mm (recommended slim fans for GPUs wider than 2.5 PCI slots)
  • Motherboard Support Mini DTX
  • Materials Mesh
  • Expansion Slots 3
  • Pre-installed Fans - Rear 1x 92mm 650-2300RPM PWM (SickleFlow)
  • Fan Support - Top 2x 120mm
  • Motherboard Support Max MB size: 244 x 226mm (L x H)
  • Radiator Support - Top N/A
  • I/O Panel 2x USB 3.2 Gen 1 Type-A
  • Clearance - CPU Cooler 155mm
  • Clearance - PSU 130mm
  • Clearance - CPU Cooler 76mm (GPU in vertical position)
  • Power Supply Support SFX
  • Power Supply Support SFX-L
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • 3.5" Drive Bays 1 (Max. 2)
  • Clearance - GFX L: 330mm (incl. power connector)
  • Clearance - GFX H: 156mm (incl. power connector)
  • Clearance - GFX W: 60mm (triple slot)
  • Weight 4.8 kg
  • 2.5" Drive Bays 2 (Max. 3)
  • Dimensions (L x W x H) 376 x 185 x 292mm incl. Protrusions
  • Dimensions (L x W x H) 360 x 185 x 274mm excl. Protrusions
  • Model Number MCB-NR200-WNNN-S00
  • Model Number MCB-NR200-KNNN-S00
