MasterBox K501L ARGB Mid Tower PC Case image number 0
MasterBox K501L ARGB Mid Tower PC Case image number 1
MasterBox K501L ARGB Mid Tower PC Case image number 2
MasterBox K501L ARGB Mid Tower PC Case image number 3
MasterBox K501L ARGB Mid Tower PC Case image number 4
YOUR ANGLE OF ATTACK
Gaming is in the core of the new MasterBox K501L ARGB. Donning an illuminated fan against the angled front panel ventilation speaks to its competitive
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • 5.25" Drive Bays 0
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Pre-installed Fans - Bottom N/A
  • Clearance - PSU 180mm/7.08"
  • Volume 40.3L (exlc. Protrusions)
  • Materials Tempered Glass
  • Radiator Support - Top 360mm
  • Motherboard Support SSI CEB
  • Power Supply Support ATX
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • I/O Panel 1x USB 2.0
  • Motherboard Support E-ATX*
  • Fan Support - Bottom N/A
  • Radiator Support - Bottom N/A
  • Expansion Slots 7
  • Motherboard Support ATX
  • Cable Routing 19mm/0.74"
  • I/O Panel 1x USB 3.0 Type-A
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 3x 120mm
  • Radiator Support - Top (44mm max motherboard component height)
  • Motherboard Support (*up to 12” x 10.7” motherboards)
  • Clearance - PSU 295mm/11.61" (w/ HDD cage removed)
  • Pre-installed Fans - Front 2x 120mm ARGB Fan
  • Clearance - GFX 410mm/16.1"
  • I/O Panel 1x 3.5mm Mic Jack
  • 2.5" Drive Bays 4 (2+2 combo)
  • Dimensions (L x W x H) 496mm x 217mm x 469mm (incl. Protrusions)
  • Dimensions (L x W x H) 428.7mm x 205mm x 458.5mm (excl. Protrusions)
  • UPC Code 884102082122
  • EAN Code 4719512109816
  • Model Number MCB-K501L-KGNN-SR3
