CMP 520 image number 0
CMP 520 image number 1
CMP 520 image number 2
CMP 520 image number 3
CMP 520 image number 4
CMP 520 image number 5
CMP 520 image number 6
CMP 520 image number 7
CMP 520
CMP 520
CMP 520
CMP 520
CMP 520
CMP 520
CMP 520
CMP 520
Cutting Edge Brilliance
CMP 520
CMP 520's asymmetrical front panel design frames the pre-installed three 120mm ARGB fans as unique centerpieces on the build.
Three 120mm ARGB Fans Included
Mesh Geode Front Panel
Versatile Cooling Options
Full Black Coating & PSU Cover
Buy Now
  • Model Number CP520-KGNN-S00
  • Exterior Color Black
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 439 x 204 x 463mm (Incl. Protrusions), 432 x 204 x 448mm (Excl. Protrusions)
  • Volume 41.34L (Excl. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 2
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 2.0
  • ARGB Controller ARGB Fans Hub
  • Pre-installed Fans - Front 3x CF120 ARGB
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Front 3x 120mm, 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 240mm* (*RAM height below 35mm)
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Clearance - CPU Cooler 161mm
  • Clearance - PSU 160mm
  • Clearance - GFX 350mm (w/o front fans & radiator)
  • Cable Routing 18.5mm
  • Dust Filters Top, Bottom
  • Size Mid Tower
  • Series CMP Series
  • CMP 520 Product Sheet (CF120 ARGB+Hub) SN after CP520KGNNS001224700001 Download
  • CMP 520 Product Sheet (CF120P ARGB+CF120S ARGB) Download
  • CMP 520 Manual (CF120 ARGB+ Hub SN after CP520KGNNS001224700001) Download
