CM Force 251 image number 0
CM Force 251 image number 1
CM Force 251 image number 2
CM Force 251 image number 3
CM Force 251 image number 4
CM Force 251
CM Force 251
CM Force 251
CM Force 251
CM Force 251
CM Force 251
CM Force 251
  • Color(s) Black
  • Size Mid Tower
  • Legacy Cases
  • Maximum Compatibility - VGA Card Length 245mm / 9.6 inch
  • Maximum Compatibility - CPU Cooler Height 129mm / 5.1 inch (With the Side Fan)
  • Cooling System - Rear 80/90/120mm fan x 1 (optional)
  • I/O Panel 2x USB 2.0
  • Cooling System - Side 80/90/120mm fan x 2 (optional)
  • Maximum Compatibility - CPU Cooler Height 154mm / 6.0 inch (Without the Side Fan)
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Cooling System - Front 120mm fan x 1 (installed)
  • Net Weight 3.9 kg / 8.6 lbs
  • 5.25" Drive Bays 2 (exposed)
  • I/O Panel 1x Mic
  • 3.5" Drive Bays 8 (1 exposed, 7 hidden)
  • Dimensions (L x W x H) 180 x 416.6 x 429.5 mm / 7.1 x 16.4 x 16.9 inch
  • Model Number FOR-251-KKN1
