null image number 0
null image number 1
null image number 2
null image number 3
null image number 4
null
null
null
null
null
Hyper 622 Halo White
ARGB Auto Detection
Broad Case Fitment
Aluminum Top Cover
Dual Redesigned Halo² Fan
Dual Tower Heat Sink with 6 Heat Pipes
Buy Now
  • Product Number RR-D6WW-20PA-R1
  • Exterior Color White
  • Dimensions (L x W x H) 125 x 137 x 157 mm / 4.9 x 5.3 x 6.1 inch
  • Heat Sink Material 6 Heat Pipes / Aluminum Fins
  • Fan Quantity 2 PCS
  • Fan Speed 650-2050 RPM ± 10%
  • Fan Airflow 51.88 CFM (Max)
  • Fan Air Pressure 2.89 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 27 dBA (Max)
  • Fan Rated Current 0.28A
  • Fan Safety Current 0.54A
  • Fan Power Consumption 3.36W
  • Series Hyper
  • Cooler Type Air Cooler
  • Heatpipes 6
