MasterLiquid 240L Core ARGB image number 0
MasterLiquid 240L Core ARGB image number 1
MasterLiquid 240L Core ARGB White
New Gen S Dual Chamber Pump
Expanded Radiator Surface
120mm ARGB Fans
Clean Classic Design
CryoFuze Performance Thermal Paste
Buy Now
CLEAN
CLASSIC DESIGN
Clean minimalist design brings a refreshed modern facelift to the pump cover.
CRYOFUZE THERMAL PASTE
Includes premium CryoFuze thermal paste for exceptional heat conductivity.
Redesigned copper base targets heat spots with precision along with boosted water flow and pressure for enhanced cooling performance.
120mm ARGB Fans
Upgraded 120mm ARGB fans deliver optimal radiator performance and versatile lighting options.
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • Product Number MLW-D24M-A18PZ-RW
  • Exterior Color White
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 277 x 119.6 x 27.2 mm / 10.9 x 4.7 x 1.1 inch
  • Pump Dimensions 81 x 76 x 47 mm / 3.2 x 3 x 1.9 inch
  • Pump MTTF >70,000 Hours
  • Pump Noise Level 12 dBA (Max)
  • Pump Connector 3-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 3.96W
  • Fan Quantity 2 PCS
  • Fan LED Type ARGB
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan Pressure 1.86 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • Warranty 3 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
  • Radiator Size 240
