CMP 320 image number 0
CMP 320 image number 1
CMP 320 image number 2
CMP 320 image number 3
CMP 320 image number 4
CMP 320 image number 5
CMP 320 image number 6
CMP 320 image number 7
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
Cutting Edge Brilliance
CMP 320
CMP 320 offers premium aesthetics, optimal thermals, brilliant performance: all while taking up minimal space on your gaming room.
Two 120mm ARGB Fans Included
Mesh Geode Front Panel
Versatile Cooling Options
Full Black Coating & PSU Cover
Buy Now
  • Model Number CP320-KGNN-S00
  • Exterior Color Black
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 445.5 x 204 x 425mm (Incl. Protrusions), 431.8 x 204 x 410mm (Excl. Protrusions)
  • Volume 38.52L (Excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 2
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 2.0
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • ARGB Controller ARGB Fans Hub
  • Pre-installed Fans - Front 2x CF120 ARGB
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Front 2x120mm / 3x120mm (*Installed inside the case only)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280mm (*Recommend AIO tubes face rear to avoid interference)
  • Clearance - CPU Cooler 163.5mm
  • Clearance - PSU 160mm
  • Clearance - GFX 365mm (without front fans & radiator)
  • Cable Routing 16.5mm
  • Dust Filters Top, Bottom
  • Size Mini Tower
  • Series CMP Series
  • CMP 320 Product Sheet (CF120 ARGB+Hub) SN after CP320KGNNS001224700001 Download
  • CMP 320 Product Sheet (CF120P ARGB+CF120S ARGB) Download
  • CMP 320 Manual (CF120 ARGB+ Hub SN after CP320KGNNS001224700001) Download
