Flex Your Graphics Muscle
The Cooler Master Riser Cable PCIe 5.0 x16 – 200mm is engineered for superior data transmission, maximum flexibility, and long-lasting durability. High-quality plastic materials enhance cable strength and flexibility, ensuring easy installation even in the tightest PCIe slots.
Heavy-duty shielding protects against electromagnetic interference, preserving signal integrity and stability. Meanwhile, the multi-layer coated PCB delivers industry-leading cable flex, moisture resistance, and reliable performance under high thermal loads.
