This edition of the MasterLiquid series has been specially designed for AMD TR5-SP6 CPUs only
Large, full-coverage copper base
The extensive copper base spreads heat more evenly across the cooling surface, allowing for quicker dissipation and maintaining lower CPU temperatures even under heavy loads.
Mobius 120 fans
Our critically acclaimed Mobius 120 fans provide both high-end thermal performance and unparalleled noise control
All-in-one thermal solution
Pre-applied thermal paste and easy snap-on brackets make installation and set-up a breeze
