The LCD panel provides a real-time display, and the MasterCTRL software supports the creation of GIFs, PNGs, JPGs, scrolling text, and the display of your music or video source.
360 DEGREES OF COOL
MasterLiquid Atmos II LCD
⬢ LCD panel for enhanced personalization
⬢ SickleFlow Edge ARGB fans
⬢ Ultra-low profile pump design
⬢ Quick and easy installation
MASTERLIQUID ATMOS II LCD
Introducing Cooler Master’s all-new Atmos II LCD CPU cooler, designed to elevate your cooling experience. The MasterLiquid Atmos II LCD offers enhanced customization, enabling users to switch the panel information to system stats, GIFs, images, scrolling text and more. The low-profile pump design makes it ideal for fitting into compact cases. The MasterLiquid Atmos II LCD delivers exceptional cooling performance, quieter operation, and the flexibility to personalize your build. Make it yours with Atmos II LCD—the perfect blend of performance, customization, and silence.
Patented design
Improved Quality
Engineered with PPS and fiberglass, the MasterLiquid Atmos II pump housing delivers industrial-grade strength, exceptional heat resistance, and unmatched durability—designed for builders who demand long-lasting, high-performance cooling. It also passes extreme testing at 70°C for 3,000 hours and 120 °C for 12 hours*, ensuring reliable performance under the harshest conditions.
*Tested by Cooler Master Lab using only the liquid cooling module. Results may vary by system and conditions.
High RPM fan with low vibration ensure strong cooling with minimal noise, while the dual color options complement different system aesthetics.
ULTRA-LOW PROFILE PUMP DESIGN
The flat design allows installation in cases of different sizes while maintaining strong performance.
QUICK AND EASY INSTALLATION
A quick-mount kit ensures compatibility with mainstream processor sockets and the pre-installed fans simplify setup.
Offset Mounting Brackets for LGA 1851
Due to the varying CPU hotspots across different platforms, there are corresponding mounting bracket solutions tailored for each. We recommend you use the included offset mounting brackets for LGA 1851*, which precisely dissipate 4°C of heat from the center of the CPU.**
*Please check whether your motherboard is compatible with this offset bracket.
**Tested by Cooler Master Lab.
THERMAL PASTE
