Front and side glass panels with beveled edges highlight your lighting and key components.
Smaller footprint fits tight spaces—without sacrificing radiator or GPU support.
Delivers high-end cooling typically found in full-size ATX cases.
Up to 9 fans enable bottom-to-top airflow for effective heat management.
