Cooler Master Announces North American Availability of MasterFrame 500 Mesh
Open-frame, high-airflow ATX chassis with dual 200 mm fans, dual 360 mm radiator support, and serious mod potential lands August 19
Summary
Los Angeles, July 29, 2025. Cooler Master, a global leader in innovative thermal solutions and PC hardware, today announced North American availability of the MasterFrame 500 Mesh, a premium open-frame ATX chassis built for extreme cooling and straightforward customization. Developed under Cooler Master’s FreeForm 2.0 design philosophy, it gives builders the structure, airflow, and files they need to tailor the frame to their vision.
The chassis features an exposed exo-structure, mesh panels for stronger airflow, support for Mini-ITX to E-ATX motherboards, and GPU clearance up to 390 mm. ARGB and non-ARGB versions both ship with dual SickleFlow 200 mm front fans and a 120 mm rear fan. With room for up to eight fans and two 360 mm radiators, the platform is ready for high thermal loads, silent tuning, or both.
“MasterFrame 500 Mesh is about access, airflow, and making the frame yours,” said Wei Yang, General Manager North America, Cooler Master. “If you want to tweak layouts, swap panels, or publish your own mods, it’s built to encourage that.”
Key features
• Open-frame exo-structure for unrestricted access and flexible layouts
• High-airflow mesh panels with dual 200 mm SickleFlow front fans pre-installed
• Dual 360 mm radiator support and capacity for up to eight fans
• Mini-ITX to E-ATX compatibility and 390 mm GPU clearance
• Tool-free panel removal, USB 3.1 Type-C, and an included GPU support bracket
• Built with FreeForm 2.0 in mind, including access to open design files for community-led modification
Availability
MasterFrame 500 Mesh (Silver and Black) will be available in North America on August 19 at coolermaster.com and select retailers. Visit our product page to sign up for the earliest availability.
About Cooler Master
