New
UNLEASH NEXT-GEN MIGHT
X Mighty Platinum 2000 | Next Gen Might
Cooler Master's X Mighty Platinum power supply ensures next-level performance. Experience the pinnacle of power with X Mighty Platinum.
Unleash Next-Gen Might
The X Mighty Platinum is a powerhouse blending high-capacity performance, top-tier industrial-grade IC components, and sophisticated interleaved PFC topology. This PSU is engineered to meet the demanding needs of server and artificial intelligence industries, featuring dual 12V-2x6 connectors designed for rigorous, high-performance applications.
AI-Ready Dual GPU Support with Color-Coded Precision
Supports dual 12V-2x6 connectors for dual GPU configurations, ideal for AI and machine learning workloads. Features dual-color connects (black and purple) to ensure correct installation.
Infineon Industrial-Grade Chipset for Enduring Reliability
Infineon industrial-grade chipset ensures long-lasting reliability
Active Bridge Rectifier for Boosted Efficiency and Stability
Active bridge rectifier for enhanced power efficiency and stability
Advanced Aluminum Design for Superior Cooling and Durability
Advanced aluminum thermal structure ensures excellent heat dissipation and durability
Premium Japanese Capacitors for Silent, Long-Lasting Performance
High-quality Japanese capacitors improve longevity and reduce electrical noise
PMBus Support for Enterprise-Grade Performance Monitors
PMBus port support offers enterprise-grade performance monitoring capability
Digital Power Management System
& MasterCTRL
Equipped with MCUs and Integrated with MasterCTRL software, our reliable PSU meticulously monitors temperature, current load and efficiency in real-time, offering precise and direct oversight.
