• Produtos
    ProdutosProdutos
    • RESFRIAMENTO
      RESFRIAMENTORESFRIAMENTO
      • Air Cooler
      • Water Cooler
      • Ventoinhas para Gabinete
      • Pasta Térmica
      • Resfriamento para Notebook
      • Cooler Padrão para CPU
      • Resfriamento para Celular
    • GABINETES
      GABINETESGABINETES
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • Acessórios para gabinetes
    • FONTES DE ALIMENTAÇÃO
      FONTES DE ALIMENTAÇÃOFONTES DE ALIMENTAÇÃO
      • Série X
      • Série V
      • Série V SFX
      • Série GX
      • Série MWE
      • Série Elite
    • PERIFÉRICOS
      PERIFÉRICOSPERIFÉRICOS
      • Monitores
      • Teclado
      • Mouse
      • Audio
      • Mouse pads
      • Controles
    • MÓVEIS
      MÓVEISMÓVEIS
      • Cadeiras
      • Mesas
      • Acessórios
    • SISTEMAS
      SISTEMASSISTEMAS
      • MasterHub
        MasterHubMasterHub
        • SÉRIE MAX
          SÉRIE MAXSÉRIE MAX
          • ATX
          • Mini ITX
        • EXPERIÊNCIA IMERSIVA
          EXPERIÊNCIA IMERSIVAEXPERIÊNCIA IMERSIVA
          RESFRIAMENTO
          360 DE RESFRIAMENTO
          GABINETES
          O PRECISO PODER SILENCIOSO
          PERIFÉRICOS
          MÓVEIS
          RELAXAMENTO AO SEU COMANDO
          SISTEMAS
          FRIO. COMPACTO. SILENCIOSO.
          MasterHub
          SÉRIE MAX
        • Builder's Zone
          Builder's Zone
          • Calculadora de PSU
          • Compatibilidade de CPU
          • Guia e Recursos
          Builder's Zone
        • Software
          Software
          • MasterHUB
          • Masterplus+
          • Masterctrl
          Software
        • Suporte
          Suporte
          • REGISTRO DE PRODUTO
          • SUPORTE TÉCNICO
          • GARANTIA
          • VERIFICAÇÃO DE GARANTIA
          • PERGUNTAS FREQUENTES (FAQ)
          • CONTATO
          • ONDE COMPRAR
          Suporte
          Anúncio Especial
        Universal Vertical GPU Holder Kit ARGB
        Overview
        1. Home/
        2. PC Cases/
        3. Pc Cases Accessories/
        4. Universal Vertical GPU Holder Kit ARGB
        New
        Illuminating Perfection
        Elevate your gaming setup with the Universal Vertical GPU Holder Kit ARGB and stand out among fellow gamers. Show off your components with pride and unlock the full potential of your gaming experience.
        Rotatable ARGB Lighting
        A 270° ARGB lighting strip curved with Cooler Master symbol offers style options from minimal to maximal illumination.
        Ultra-flexible PCIe 4.0 Riser Cable Included
        Ultra-flexible PCIe 4.0 riser cable enables high-speed data transmission with ease for tight cable routing.
        Tool-less, Instantly Adjustable Design
        Toollessly adjustable up to 65mm horizontally, as well as up to 30mm towards the side panel for easy installation.
        Effortlessly Showcase Your Graphics Card
        Bring the best out of your components by showing off your GPU.
        ATX & M-ATX
        COMPATIBILITY
        Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market.
        PCIe Slot Quick Release System
        Enabling painless graphic card uninstallation for hassle-free upgrades and maintenance with the Quick Release System.
        The Ultimate Solution For Vertical GPU Mounting
        Trending
        GX Gold 650 Full Modular
        Discover
        HAF 700 Gabinete Full Tower
        O Berserker
        Discover
        GX Gold 750 Full Modular
        Fonte de alimentação ATX totalmente modular 80 Plus Gold
        Discover
        GX Gold 850 Full Modular
        Discover
        logoEste site é destinado apenas a produtos de consumo da Cooler Master Technology Inc. Para produtos OEM/ODM, acesse Cooler Master Co. Ltd.
        • Sobre
          Corporativo
          Mídias Sociais
          Notícias
          Eventos
        • Suporte
          Registro de Produto
          Especificações Técnicas
          Garantia
          Verificação de Garantia
          Perguntas Frequentes (FAQ)
          Contate-nos
        Carreira
        Centro de Recursos
        © Cooler Master Technology Inc.
        • Política de Privacidade
        • Termos de Uso
        • Política de Cookies
        • Termos e Condições Gerais
        • Conformidade dos Produtos
        Confirm your Country
        It seems you are from Estados Unidos
        The page you're looking shows Cooler Master contents for Brasil.
