• Produtos
    ProdutosProdutos
    • RESFRIAMENTO
      RESFRIAMENTORESFRIAMENTO
      • Air Cooler
      • Water Cooler
      • Ventoinhas para Gabinete
      • Pasta Térmica
      • Resfriamento para Notebook
      • Cooler Padrão para CPU
      • Resfriamento para Celular
    • GABINETES
      GABINETESGABINETES
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • Acessórios para gabinetes
    • FONTES DE ALIMENTAÇÃO
      FONTES DE ALIMENTAÇÃOFONTES DE ALIMENTAÇÃO
      • Série X
      • Série V
      • Série V SFX
      • Série GX
      • Série MWE
      • Série Elite
    • PERIFÉRICOS
      PERIFÉRICOSPERIFÉRICOS
      • Monitores
      • Teclado
      • Mouse
      • Audio
      • Mouse pads
      • Controles
    • MÓVEIS
      MÓVEISMÓVEIS
      • Cadeiras
      • Mesas
      • Acessórios
    • SISTEMAS
      SISTEMASSISTEMAS
      • MasterHub
        MasterHubMasterHub
        • SÉRIE MAX
          SÉRIE MAXSÉRIE MAX
          • ATX
          • Mini ITX
        • EXPERIÊNCIA IMERSIVA
          EXPERIÊNCIA IMERSIVAEXPERIÊNCIA IMERSIVA
          RESFRIAMENTO
          360 DE RESFRIAMENTO
          GABINETES
          O PRECISO PODER SILENCIOSO
          PERIFÉRICOS
          MÓVEIS
          RELAXAMENTO AO SEU COMANDO
          SISTEMAS
          FRIO. COMPACTO. SILENCIOSO.
          MasterHub
          SÉRIE MAX
        • Builder's Zone
          Builder's Zone
          • Calculadora de PSU
          • Compatibilidade de CPU
          • Guia e Recursos
          Builder's Zone
        • Software
          Software
          • MasterHUB
          • Masterplus+
          • Masterctrl
          Software
        • Suporte
          Suporte
          • REGISTRO DE PRODUTO
          • SUPORTE TÉCNICO
          • GARANTIA
          • VERIFICAÇÃO DE GARANTIA
          • PERGUNTAS FREQUENTES (FAQ)
          • CONTATO
          • ONDE COMPRAR
          Suporte
          Anúncio Especial
        1. Home/
        2. Guide & Resources/
        3. What is Cyberetics Noise Level?
        WHAT IS CYBENETICS NOISE LEVEL?
        In the process of selecting a PSU for your PC build there are numerous factors to consider in order to correctly choose the best unit for your machine and preferences. One of those factors is noise level. How can you be sure about a PSU’s noise level? That’s where Cybenetics comes in. Much like 80 Plus efficiency ratings, Cybenetics noise level certifications ensure that a PSU’s noise output has been tested and rated accordingly by a third-party agency. Let’s get into the details about what PSU noise is, who is Cybenetics, and how the certifications work.
        in this article
        • What is PSU noise?
        • Who is Cybenetics?
        • How does their certification program work?
        • Conclusion
        What is Cybenetics Noise Level
        What is PSU noise?
        It may seem strange at first, but PSU’s do produce noise, usually while operating at higher loads. The reason is simple: fans. It’s well known that case fans and cooler fans can make noise, and the PSU is no different. The loader any of your fans are, the more they will contribute to your PC’s overall noise level. So if you want to keep things quiet so you can stay focused, it’s a good idea to keep Cybenetics noise levels in mind when shopping around for a PSU.
        Who is Cybenetics?
        Cybenetics Labs is a Cyprus-based company that was founded to provide a new level of accuracy to PSU testing for both efficiency and noise level. The company seeks to improve and expand the information available to customers in order to support well-informed decision making when builders are looking to buy a PSU. With more than two decades of experience and a focus on high quality in both equipment and measurement, Cybenetics is a highly trustworthy source of information for reliable PSU noise level testing.
        To put it simply, Cybenetics calculates a PSU’s overall noise output by averaging testing noise measurements. The details of the process are anything but simple, however. Decibels, or dB, work on a logarithmic scale which makes measurement difficult. So Cybenetics converts noise measurements taken in dB to sound pressure units, or Pa, averages the Pa numbers, and then converts the units back into dB to make it easier for most people to understand the rankings. Cybenetics categorizes PSUs into 7 noise level rankings ranging from rather loud to basically silent. The rankings are as follows, from loudest to quietest:
        So, if you want your PSU to be as quiet as can be, going for A++ would be ideal. However, any PSU in the A range of rankings is guaranteed to be exceptionally quiet. For example, Cooler Master’s GX III Gold 850 has received an A- Cybenetics certification, indicating excellent quiet performance.
        Conclusion
        That does it for Cybenetics noise level rankings! If you would like to check out Cooler Master’s own selection of Cybenetics-certified PSUs, please visit this page to see which of our PSUs have received a Cybenetics certification.
        logoEste site é destinado apenas a produtos de consumo da Cooler Master Technology Inc. Para produtos OEM/ODM, acesse Cooler Master Co. Ltd.
        • Sobre
          Corporativo
          Mídias Sociais
          Notícias
          Eventos
        • Suporte
          Registro de Produto
          Especificações Técnicas
          Garantia
          Verificação de Garantia
          Perguntas Frequentes (FAQ)
          Contate-nos
        Carreira
        Centro de Recursos
        © Cooler Master Technology Inc.
        • Política de Privacidade
        • Termos de Uso
        • Política de Cookies
        • Termos e Condições Gerais
        • Conformidade dos Produtos
        Confirm your Country
        It seems you are from Estados Unidos
        The page you're looking shows Cooler Master contents for Brasil.
