V SFX Gold 850 ATX 3.0 image number 0
V SFX Gold 850 ATX 3.0 image number 1
V SFX Gold 850 ATX 3.0 image number 2
V SFX Gold 850 ATX 3.0 image number 3
V SFX Gold 850 ATX 3.0 image number 4
V SFX Gold 850 ATX 3.0 image number 5
V SFX Gold 850 ATX 3.0 image number 6
V SFX Gold 850 ATX 3.0 image number 7
V SFX Gold 850 ATX 3.0 image number 8
Small But Mighty
• Flexible compatibility
• 80 PLUS Gold certified
• Fully modular cabling
• High-quality Japanese capacitors
• 10-year Warranty
U.S. Shipping:
Ships from California
Price reduced from $139.99 to $119.99
SMALL BUT MIGHTY
SMALL BUT MIGHTY
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
FLEXIBLE COMPATIBILITY
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
80 PLUS GOLD CERTIFIED
The V SFX Gold is certified to achieve more than 90% efficiency at typical loads.
90-DEGREE 12VHPWR CABLE
HIGH-QUALITY JAPANESE CAPACITORS
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
FULLY MODULAR CABLING
PSU CALCULATOR
  • Model MPY-8501-SFHAGV-3**
  • Input Current 12-6A
  • Fan Size 92mm
  • Fan Bearing FDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time 16ms
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, RCM, CB, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 4
  • 12VHPWR Connector 1
  • Series V SFX Series
  • 80 Plus Efficiency Gold
  • Category Above 750W
  • Form Factor SFX
  • Watts 850W
  • ATX Version ATX 3.0
  • ETA Rating Gold
  • LAMBDA Rating Standard+
