V Platinum 3000 Workstation image number 0
V Platinum 3000 Workstation image number 1
V Platinum 3000 Workstation image number 2
V Platinum 3000 Workstation image number 3
V Platinum 3000 Workstation image number 4
V Platinum 3000 Workstation image number 5
V Platinum 3000 Workstation image number 6
V Platinum 3000 Workstation image number 7
V Platinum 3000 Workstation image number 8
V Platinum 3000 Workstation image number 9
Platinum Power for AI & Workstation Builds
• Ultra-high 3000W output for heavy-duty workstation builds
• Supports ATX 3.1 and PCIe 5.1 standards
• Equipped with 4 × 12+4 pin connectors for multiple high-end GPUs
• 80 PLUS Platinum-certified efficiency to reduce power loss and heat
• FDB cooling fan for quiet operation and efficient thermal performance
• All-Japanese capacitors for improved reliability and durability
• Industrial-grade protection against dust, moisture, and corrosion
• Premium embossed cables for a clean and durable build
• Backed by a 12-year warranty for long-term peace of mind
U.S. Shipping:
Ships from California
Built for extreme workstation and AI computing, the V Platinum 3000 Workstation delivers massive 3000W output with high-efficiency 80 PLUS Platinum performance. Designed for multi-GPU systems and demanding professional workloads, it provides reliable power, advanced cooling, and long-term durability.
80 PLUS PLATINUM THERMAL EFFICIENCY
Minimizes power loss and heat buildup to keep AI workloads running cooler and more efficiently.
ATX 3.1 & PCIe 5.1 Ready
Supports the latest power standards for next-generation GPUs, motherboards, and AI accelerators.
FDB COOLING FAN
Equipped with a Fluid Dynamic Bearing fan for long lifespan, and efficient heat dissipation under heavy loads.
ALL-JAPANESE CAPACITORS FOR LONG-HAUL STABILITY
Delivers reliable, consistent power under high temperatures and sustained full-load operation.
DUAL-COLOR 12+4 PIN CONNECTORS
Makes GPU power installation faster, safer, and easier with clear color-coded guidance.
EMBOSSED PREMIUM CABLES
Enables clean cable routing, improved airflow, and lasting durability inside dense workstation builds.
INDUSTRIAL-GRADE PROTECTION
Guards against dust, moisture, and corrosion for dependable operation in demanding environments.
12-YEAR WARRANTY
Backs premium engineering and long-term reliability for mission-critical AI & workstation power.
  • Product Name V PLATINUM 3000 WORKSTATION
  • Product Number MPV-U0S1-AFP
  • Input Voltage 220 – 240V
  • Input Current 16A max
  • Input Frequency 50 – 60Hz
  • Dimension (L x W x H) 202 x 150 x 86 mm
  • Fan Size 140 mm
  • Fan Bearing FDB
  • Efficiency ≥ 94% @ Typical Load
  • 80 PLUS Rating 80 PLUS PLATINUM
  • Operating Temperature 0 ~ 45℃
  • Power Good Signal 100 – 150ms
  • Hold Up Time ≥ 11ms @ 100% Load
  • Protections UVP / OVP / OCP / OPP / OTP / SCP
  • Regulatory cTUV us, CB, CE, FCC, BSMI, CCC, RCM, UKCA, BIS, KC, RoHS2.0
  • Connectors - ATX 24 Pin x1 = 1 (600mm)
  • Connectors - EPS 4+4 Pin x1 = 1 (650mm)
  • Connectors - EPS 8 Pin x1 = 1 (650mm)
  • Connectors - SATA X12(s) =3 [500(s)+120(s)+120(s) +120(s)mm]
  • Connectors - Peripheral 4 Pin X4(p) =1 [500(p)+120(p)+120(p) +120(p)mm]
  • Connectors - PCI-e 6+2 Pin x12 = 2 (650mm)/5(650+120mm)
  • Connectors - 12+4 Pin x4 = 4 (650mm)
